After replacing the brakes they are not working and there is air in the line I cannot get it out
1999 FORD FALCON
25,000 MILES
THERESA PARNABY
I put new brakes in and it is suck air in line and we have try to bleed it, but there is no brakes and air is getting in the brakes line somewhere.
Jan 5, 2020 at 1:53 AM
When you say the new brakes, what was done? If it was only brake pads or shoes, the system wouldn't have been opened.
Next, if you pump the brakes, does the brake pedal pump up? Keep in mind, the brake system is a sealed system and no air should be able to get into it. If there are no leaks and the fluid doesn't change level, either the bleeding process is not being followed, the master cylinder is bad, someone reversed the brake caliper side causing the bleeder to be on the bottom, or something is bad and allowing fluid to enter.
Take a look through this link:
.https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Also, here is a link that explains how to bleed them. Let me know if this is how you did it.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Let me know exactly what was replaced, the symptoms you have, and if the above listed links are helpful.
I will watch for your reply
Jan 5, 2020 at 7:13 PM
