Started having a problem with my front left brake caliper. Started sticking to the disc and giving off a bad smell. Got worse and wheel would not turn. Mechanic friend blocked off the fluid and depended on the right side to work as a temporary fix. 2 days later and the right side Started doing the same. Started with a bad smell and then the pads sticking to the disc.
Ended up stuck on the road as the brakes which was now only working on the right side sticked to the wheel and didn't release. Stood for about 15 mins and then I could drive again. Wheels moving. Just got home and didn't drive for about 5 hours or so. Got into the car to head to the store and felt a very soft pedal, sinking easily. Driving for a bit longer and the pedal started getting harder again.
What could be the issue? Both calipers packing up at the same time?
Sep 11, 2025 at 1:36 PM
