After replacing brakes pedal goes to the floor
2015 KIA SOUL
30,000 MILES • 4 CYL • 2WD • AUTOMATIC
SCOTT JACKSON2
Replaced driver side rear caliper and all new brakes. Had no good pedal. Starting with passenger rear I bled all lines and pass side rear makes a squishing noise but nothing comes out except fluid. I bled a quart through the passenger rear which is extreme amount still makes squishing noise when being bled. Pedal still goes to floor but brakes will stop the car. Do I still have trapped air and do I need to keep bleeding until noise goes away?
Dec 23, 2018 at 7:12 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Yes, it sounds like you still have air trapped in the system. Just so you know whenever a line is opened you need to bleed all four brake calipers. I've attached a tutorial showing what is involved.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Hope this helps and feel free to ask any questions if needed.
Danny-
Dec 24, 2018 at 12:32 AM
SCOTT JACKSON2
I have never seen a car that you have to run more than a pint through the system and it still showing signs of trapped air. Is this something you have seen? We bled them for two hours and still making squishing sound on rear passenger side when bleeder is opened. all other lines being driver side and passenger front make no sound when bleeder is opened. We have ran a quart through passenger rear and still making a flowing noise when you pump the brake and hold it and open that rear bleeder. Should I just keep doing it even if runs into half a day and a gallon of fluid?
Dec 24, 2018 at 2:24 AM
DANNY L
  • 5,648 POSTS
Hello again.
Yes, I have noticed a few times cars that were difficult to bleed. Is it just fluid coming out when bleeding or are you still noticing air bubbles? Hope this helps and thanks again for using 2CarPros.
Danny-
Dec 24, 2018 at 3:35 PM
SCOTT JACKSON2
just fluid but makes a squishing sound when you open right rear bleeder, but no air comes out.
Dec 25, 2018 at 8:03 AM
It sounds like you may have the caliper on wrong if no air comes out. Can you take a pair of vise grips and gently close of the rubber line to the caliper to see if the brake pedal is better? Also recheck your work of the caliper mount here is a diagrams to help us.
The pad has a notch that must be installed correctly or you will have low pedal.
This video show the job being down on a different car but the process is the same, it shows how to use the tool.
https://youtu.be/hPzxdnLJbhc
Dec 27, 2018 at 6:28 PM
Any luck on this Scott?
Apr 8, 2019 at 10:12 AM
