Yea, two bled & two wont also replaced far rear hose, it calapsed i think
Jan 10, 2016 at 6:52 PM
69L88
MEMBER
It will act as if its bled and after start goes to floor
Jan 10, 2016 at 6:55 PM
PACO8224
CERTIFIED EXPERT
Does it go to floor slowly after start? Or just fast with no pedal at all
Jan 10, 2016 at 7:06 PM
69L88
MEMBER
Very slow with some effort also
Jan 10, 2016 at 8:20 PM
PACO8224
CERTIFIED EXPERT
Check to verify there is no lines leaking nowhere. After checking that and you do not see no brake fluid leaking nowhere replace the master cylinder, there is a internal leak in the master cylinder if no visual leaks are found.
Jan 10, 2016 at 8:24 PM
69L88
MEMBER
Thank you,i never had experience ,and didn't knoe symtoms.
Jan 10, 2016 at 8:30 PM
PACO8224
CERTIFIED EXPERT
Any time. Come back and check with us, we are happily to assist you.
