It sounds like the ABS system is actuating. Do you find it takes a longer distance to stop or do you have to press harder on the brake pedal?
I suspect it is likely related to a failing wheel speed sensor. That is where I would recommend starting to check.
If you have a live data scan tool, go to wheel speeds and while driving, see if each wheel is turning at the same speed. If one of the sensors is off, that can cause this to happen.
Also, if you don't have a scan tool, you can check to see if there is a sensor that is bad using a voltmeter or multimeter.
Here is a link that shows how it is done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know if that is something you are comfortable performing. Also, let me know if the ABS light or traction control light is on.
joe
Sep 9, 2023 at 8:54 PM
