Brake torque specs needed?
1995 LEXUS ES 300
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
RYAN LOBB
  • 7 POSTS
I’m going to change the brake rotors and pads on the vehicle listed above. I just need all of the caliper torque specs please. I used to have a Chilton account for my car manuals, but they discontinued that site. Thanks!
May 30, 2023 at 8:50 AM
Sure, here are the torque specs for the brake system including the calipers. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
May 30, 2023 at 6:32 PM
RYAN LOBB
  • 7 POSTS
I’m a bit confused by the titles between front and back. Which ones are caliper bracket bolts, and which are the slide pin bolts?
May 31, 2023 at 9:29 AM
RYAN LOBB
  • 7 POSTS
I’m guessing “torque plate” is the bracket bolt since it’s the highest ft.lbs
May 31, 2023 at 11:27 AM
That is correct.
Jun 2, 2023 at 8:14 AM
