I am going to change the front brakes and rotors on my vehicle
2004 GMC ENVOY
187,000 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
SWEETIE1965
  • 180 POSTS
I am going to change the front brakes and rotors on my vehicle listed above but don't know the torque specs for the caliper itself and the mounting bracket. Can you please tell me the torque specs for all brake calipers and all mounting brackets? Thanks in advance
Mar 18, 2021 at 2:34 PM
Replacing the brakes and rotors really isn't too hard. To get you started, here is a link that shows in general how it is done. You can use this as a guide.
The directions and pics below are specific to your vehicle. Torque specifications are included in the directions. I highlighted them.
Note: Pics 1-15 are pad replacement. The remaining pics are for the disc rotor.
I hope this helps. Let me know if you have other questions. Also, the pics below contain everything.
Apr 25, 2021 at 10:39 AM
SWEETIE1965
  • 180 POSTS
I need the torque specs for the caliper itself and the mounting bracket.
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Sorry for the confusion. The torque specifications are always included in the related photo instructions we include. The torque for the brake caliper to caliper bracket is to be 42 NM (Newton Meters) or 31 ft. lbs. The brake caliper bracket to hub-spindle assembly is to be 150 NM or 110 ft. lbs. I've attached pictures for you below for your vehicle. Hope this helps and thanks again for using 2CarPros.
SWEETIE1965
  • 180 POSTS
Thanks for your help.
DANNY L
  • 5,648 POSTS
You're welcome!
Thanks for using 2CarPros and we hope you will use our site again in the future when needed.
Danny-
SWEETIE1965
  • 180 POSTS
I will when I get puzzled and can't figure something out.
Thanks for jumping in, Danny. I thought I had them highlighted in the first post. Regardless, I'm glad to hear everything is taken care of.
DANNY L
  • 5,648 POSTS
Thanks again for using 2CarPros. Glad to hear you will use our site again in the future when needed. Take care.
Danny-
SWEETIE1965
  • 180 POSTS
Would the torque specs for the rear caliper and mounting be the same as the front?
DANNY L
  • 5,648 POSTS
Hello again.
No, those torque values are different. I've attached 2 pictures below showing the 2 torque values for the rear brake caliper and bracket.. Hope this helps and thanks again for using 2CarPros.
Danny-
SWEETIE1965
  • 180 POSTS
On my 2004 GMC Envoy, I changed an upper ball joint thinking that was causing a clunking sound when I run over bumps on a road. The noise is still there. I checked the hub bearing for play in the bearing. It moves about a half inch at the 3:00 and 9:00 position. I'm thinking the hub bearing is getting worn and needs to be replaced. What are your thoughts? The car runs great with a couple small dings in it. Brakes are all new along with brake rotors. Front and rear are all new. The lower ball joint seems to have no slack (play) in it.
Please post your new question here, you must be logged in.
