Brake pedal loses pressure when the engine starts
1979 CHEVROLET CORVETTE
90,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
MONTYO
When the car is shut off, the brake is firm and gets rigid within a couple pumps of the pedal, but as soon as the engine turns on, the pedal loses all pressure and drops until it's about an inch to half an inch to the floor. Pumping multiple times has no effect and the brake still loses all pressure. I have bled all calipers multiple times, and recently replaced the master cylinder, so I checked the brake booster and figured out that whenever the engine vacuum is being pulled, it causes the brakes to lose all pressure. I did this by removing the vacuum line from the brake booster, and even just me sucking air out of the booster with the little vacuum that my lungs can pull causes the brakes to go soft near immediately. Long story short, no vacuum in brake booster = very firm, any vacuum at all = very soft pedal. Now I know this is normally the booster's job, to make it easier to apply pressure to the brakes, but the brake pedal is going way lower than it should, and losing way too much pressure. The brake system on C3's is known to be terribly designed and it could still be a number of issues, but the fact that this issue only happens once the engine is turned on and the brake booster has a vacuum pulled on it means that either something is wrong with the brake booster itself, or the extra pressure supplied by the booster is somehow finding air bubbles in the system, despite the system having been bled. And this is my main question, for anyone that's had experience with something similar to this, do you think I should go ahead and get a new brake booster, or do you think there is somehow still air in the lines and the extra pressure is causing it to show itself?
Jan 4, 2021 at 10:40 AM
Good afternoon,
This sounds like the master cylinder has failed, not the booster. The inner seals in the master are not building pressure.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
I would replace the master cylinder.
Jan 4, 2021 at 12:05 PM
VINCENZO LAFRONZA
I’m having the same problem with my wife’s Jeep Wrangler. I’ve replaced the Master Cylinder once with a reman and once with a brand new one, two used ABS modules and now a brand new one, all new brake hoses, two brake boosters, multiple needs manually, ABS bleed with scan tool, pressure bleed, vacuum, and pressure bleed at the same time. Inspected all four calipers. They are literally the only thing I haven’t replaced but they work fine and don’t leak.
Pedal is hard as a rock until I start it, then it sinks almost to the floor. Pull vacuum from the booster and bam hard as a rock again.
Did you ever figure out what the issue was?
Nov 12, 2021 at 7:42 AM
Good morning,
I would first clamp off all the lines at the brake hoses with vice grips and see if you have a high hard pedal with the engine running.
If you do, then remove the vice grips one at a time until the pedal drops. That is the wheel with the issue. It could be either a caliper or a brake hose.
https://www.2carpros.com/articles/brake-caliper-replacement
If the pedal does not change, then it may be the booster itself failing.
Can you send me all the vehicle information?
Nov 13, 2021 at 8:21 AM
