I just had the front brake calipers pads rotors and bearings replaced and a master cylinder. I have driven one hundred miles and the pedal went to the floor. I was able to pump the brakes and get it stopped. I noticed that the reservoir was filled over the max line. I opened the top and the fluid sprayed out (like a hot radiator that was opened). Weird as the fluid was not that hot, but very warm bath water. I siphoned out approximately a quart and added in fresh. Pumped the brakes to get the new stuff mixed in and it seemed to work.(Temporary fix only and is going to a different shop tomorrow) But what has caused this? I have been toying with cars for years and have not seen this before. By the way, this is an International truck +/- 44,000lbs.
Jun 28, 2018 at 2:24 PM
