Yeah. I have heard of this as well. It could be the sensor as that is the most common failure, but we need to check the brake booster operation and make sure it is holding correct pressure. The fact that you are having a brake sensation issue makes me think we have an actual issue.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Please take a look at the inf below and let me know if you have questions.
I am not sure if you can rent this tool, or if it is a dealer only tool. I know you can search that tool number and buy the tool, but they are about $300.00 so that doesn't make much sense to buy one.
Basically, it would be cheaper to pay someone to inspect it for you and find out if the booster is failed or it is just a sensor.
If it is just a sensor, then that repair is about a couple hundred dollars give or take. The booster is going to be more expensive as just the part is almost $300.00.
Apr 26, 2022 at 2:11 PM
