Brake fluid is not getting to the rear calipers
2010 TOYOTA CROWN
50,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
JSRED
Just replaced rear brake pads, but the brakes are not working now. Brake fluid is not getting to the rear calipers.
Nov 19, 2017 at 12:30 AM
MHPAUTOS
  • 31,937 POSTS
Did you open the brake lines replacing the pads? You normally just push or wind back the pistons as required. if you opened the lines you will have air in the lines and a bleed will be required.
Nov 19, 2017 at 3:27 AM
