I would highly suggest we find where this fluid is going because you may have a leak. How often do you have to add fluid?
The light coming on is a fluid level sensor but that normally means the fluid is either leaking or the pads are wearing. However, if the pads are wearing causing this to happen then you most likely will only add fluid once before the pads start grinding and require replacement.
Let me know this info and we can figure out next steps. Thanks
Aug 23, 2020 at 6:03 PM
