Rear brake lines failed
1996 MERCURY VILLAGER
140,000 MILES • 3.0L • 2WD • AUTOMATIC
CJA31186
  • 89 POSTS
I took the car for repairs. They replaced the lines and bled the system. Drove the car home, realized the front driver wheel was smoking when I got back. Rim was also too hot to touch as compared to the other wheels. Took the wheel off, tried to compress the brake caliper with a c-clamp and part of the metal piston broke and the caliper did not move. What should I do to fix this? I have a little bit of experience replacing brake pads, calipers, rotors, master cylinders, and bleeding lines. Want to know the best way to approach this problem.
Jul 22, 2019 at 8:34 PM
BMDOUBLE
  • 1,139 POSTS
The driver side caliper will have to replaced now for sure, but I would also go ahead and replace both front rubber brake lines as these degrade over time and can fall apart internally and act as a check valve trapping brake fluid at the caliper and causing a brake drag situation.
Jul 22, 2019 at 9:31 PM
CJA31186
  • 89 POSTS
Okay thanks. You don't the master cylinder could be bad then? Also, what is the brake bleeding procedure for this vehicle? I've been reading differing procedures regarding pressing a valve near the master cylinder in order to bleed correctly.
Jul 23, 2019 at 5:09 AM
Here are the brake bleeding procedures for both the master and the brake system you must bunch bleed the master first.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
and
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Jul 26, 2019 at 10:24 AM
