My car listed above Sport I know has fairly bad rear drum brakes. They squeak when I press the brake. My question is (and I discovered this by accident) that when I'm stopped, pressing on the brake with the car in drive and idling. If I use my momentum and rock the car back, I hear a popping/knocking sound coming from what sounds like under the car or rear of the car. It's a pretty noticeable popping/knocking noise. Is this noise coming from my brake system, particularly the read drum brakes or something in the rear braking system? If I'm in neutral or in park, and I rock the car back it doesn't make that same sound. Thanks for any help you can give.
Jun 15, 2020 at 4:39 PM
