It sounds as though the brake master cylinder has failed. However, first check to make sure there are no leaks at any of the brake lines and wheels.
Next, take a look through this link. It explains what happens when the brake pedal goes to the floor.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
If the link contains symptoms that mirror what you experience, chances are the master cylinder is bad.
To get you started, here is a link that explains in general how one is replaced. Make sure to bench bleed the new master cylinder prior to installation.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
If you look at the attachments below, they provide the directions specific to your vehicle for replacement.
I hope this helps. Let me know if you have other questions.
See pics below.
Oct 3, 2021 at 8:38 PM
