I have bled my entire brake system four times after replacing master cylinder, wheel cylinders, calipers, rotors and new brake pads. When i bleed each brake they do not stiffen, just little bit but when i check the bleeder to see if the tubing i have on it has any air bubbles there is none. My pedal is firm when the car is off but once i turn the car on the brake pedal goes all the way to the floor easily and does not firm up even after pumping it.
Mar 22, 2018 at 2:36 PM
