Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Focus
Brakes
ABS
Wheel Speed Sensor
Replace/Remove
front wheel speed sensor replaced
2009 FORD FOCUS
82,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JESSICA TAYLOR-DOWNS
MEMBER
1 POST
FOLLOW
ABS Brake warning light is on telling me I need the front wheel speed sensor replaced.
Dec 14, 2019 at 7:49 AM
CERTIFIED EXPERT
If the wheel speed sensor has failed we need to make sure it is the sensor itself so here are some guides that will help with this:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
If the sensor is the issue then here is a guide that will help with us:
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Below you will find the process from the manual on how to replace the speed sensor. Please let us know if you other questions. Thanks
Mar 11, 2021 at 6:06 PM
CERTIFIED EXPERT
this guide can help:
Mar 15, 2021 at 7:24 PM
