With the engine off you can pull the brake booster vacuum line and if you don't hear vacuum escaping the booster is probably bad, here is a guide and video to help you change out the brake master cylinder with instructions below. I assume the brake master is full of fluid?
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
And here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
This video will help show you how to bleed the master before installation, which is a must:
https://youtu.be/WDxvEQrMkBg?si=0InuIrmcXr2e5OAx
Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Oct 9, 2023 at 10:10 AM
