Did you ever get this figured out .i have the same problem no leaks new master cylinder new calipers .Had a mechanic pull it in to his garage to check for leaks and bleed the system still no pedal.they worked fine until a brake line blew out and I replaced some line two calipers and master cylinder .everything was bled and checked for leaks
Mar 11, 2021 at 1:21 PM
CERTIFIED EXPERT
You need to have a scanner connected the ABS system so you can open the ABS valves which will get the air out.
This video will show you how to connect the the ABS system.
I bought a scanner and did an abs auto bleed .still no luck you can feel the abs push against you when the pedal goes to the floor .you can hear humming when you hold the brakes to the floor.I have someone looking at it soon .I agree maybe it’s in the abs
CERTIFIED EXPERT
Sure sounds like it but to be sure lets use four vise grips and gently close off the rubber flex hoses. Once complete check the brake pedal it should be hard if there is a wheel issue and soft if it is the master or ABS.
Please report back
DDUNCAN70
MEMBER
I took my Yukon to a second mechanic.Found out the calipers were on opposite sides .The bleeder valves have to be on top .I had replaced the rear calipers and those were fine but the front ones were mixed up .Not sure how they bled them before but if the bleeders are not on the top they are on wrong they won’t bleed correctly..thanks for the replies.brakes are great now
CERTIFIED EXPERT
Yep the calipers need to be on the correct side that's for sure quick pictures of the brakes and I could have lead us to the conclusion. Glad you got it fixed.
Use 2CarPros anytime, we are here to help. Please tell a friend.
