Brake Pedal goes to the floor when pushed. Checked the master cylinder and found no leaking
in the lines or anywhere else leaking. After you push the pedal down and it goes to the floor and if you hold it down the car wants to die. Once you let up off it, it works fine. Its like it has a vacuum leak and I cant find a leak anywhere. Can you help me find out what is wrong. A friend told me that it could be leaking internally verses externally. And it could be leaking into the brake booster. Thank You for all of your help. Please call me at 865-455-5279. I dont have any money my daughter is a diabetic and I'm afraid shell get hurt in it with the pedal going to the floor.
Oct 21, 2015 at 5:37 PM
