When you replaced these components, did you replace the wheel cylinders or calipers or just the brake components you stated? If you didn't, did you open the brake lines in other ways when doing these repairs? I would suspect there is air in the lines. These guides can help you fix it.
https://youtu.be/w7gUsj2us0U
and
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
We also need to know how you were bleeding the brakes. If this was not an issue before hand and you did not break the lines open then the only time air could have gotten into the lines is during the bleeding. the other possible cause is a failed master cylinder but again, if this was not an issue prior then we are back to how air got into the lines. Let me know and we can go from there. Thanks
Aug 28, 2020 at 7:26 PM
