After restoring my car listed above, I tested the brakes and found that with the engine off, the brake pedal was firm, but when running, the pedal sinks to the floor. This car has power disc/drum brakes.
I have done the following:
1. replaced front pads and rotors, verified calipers are on the correct side.
2. replaced master cylinder (old one had rust)
3. Booster (Bendix) was rebuilt by Booster Exchange
4. replaced Distribution block/proportioning valve (incorrect unit installed by PO, and the shuttle was frozen)
5. Bench bled MC
6. Flushed all brake lines
7. Set booster rod gap to .020" (mfg spec)
8. bled system 3 times
9. confirmed no leaks
10 verified engine vacuum (18 Hg) at booster
11. verified check valve in booster was OK
12. adjusted rear drums for a slight drag
13. performed drain-down test on booster (pump pedal 3 times, start engine, pedal goes to floor = FAIL)
Based on the results of item 13, it appears that the booster is still bad. What do you think? Are there any other tests I should perform?
5. Bench bled MC
Jul 17, 2025 at 6:43 PM
