Had bad brake line. So i replaced it the bled brakes. could not regain normal pedal. It will pump up but if you release it then press again it goes almost to floor. I then replaced master cylinder bench bleeding before installation. I then bleed brake system at ABS block then at each wheel in manufacturer's sequence. Pedal still goes almost to floor. I tried adjusting the push rod on the pedal and no luck there. I checked for leaks at all connections but found none.
Feb 16, 2019 at 2:22 PM
