It started with loss of brake fluid. Checked caliper and hoses for leaks. Suspected master cylinder leak replaced master cylinder and bled brakes.
With engine running the brake pedal now creeps and will continue to creep until pedal goes to floor. No loss of brake is evident.
Could this be caused by a by-pass from the ABS unit back to the cylinder?
Nov 5, 2021 at 11:53 PM
