Oh a Riviera! I love those cars!
Anyways, that problem is usually caused by a vacuum leak somewhere near the power brake booster. The booster has the job of pulling vacuum pressure from the engine intake manifold and using it to help you push the pedal down. When there is a leak, you have to do all of the work yourself, which makes it feel like you are trying to stop a freight train.
Vacuum lines, which are made of rubber, start to dry out and leak -or- flatten out under pressure when they get old. Time and heat cause this to happen.
The booster is located under the hood, by the firewall, driver's side of the vehicle, behind the master cylinder. The master cylinder is actually bolted to it. There is a sizable vacuum hose on it going to the intake manifold. Inspect it and all other vacuum lines. Replace as necessary. Here is a general guide on checking vacuum lines:
If you do not find a problem there, then the issue is either with the booster itself, or the check valve (the part that the vacuum hose is connected to). You can simply pull the check valve off and try blowing through it and then sucking back in. It should only allow for airflow in one direction. If it allows for flow in both directions, then replace it. It should not be more than $15.00 at the local parts store (I think). If that is not the problem, then you probably have to replace the booster itself. We will get into test and replacing it if we need to.
Nov 29, 2018 at 5:26 AM
