Dear Steve W.
Expert Mechanic.
I'm very sorry because you might not get my question clearly or maybe I don't know how to explain this correctly + I'm not a Native English speaker though.
Anyhow, if really there's an ABS system in my car, why can't I see its sign in my car's dashboard / system along with other signs.
I'm stopping the car and my leg on the brakes where the car is on but stopped by brake only, it gets this Vibration just on the brake pedal but not in the seat or wheel or any other place.
So, if we assume that the issue is one of the 4 sensors, Can I go ahead and check the car system by computer checking?
Moreover, this issue of brake pedal wasn't there before one year or so. It's a new issue just pumped out on my face.
However, I really understood the function of a sensor when it's going to die or get damaged, the car starts giving you some sort of signs so you might replace the damaged sensor.
the same issue with RPMs in a different question/thread, the sensor it might damage because it tells me that the 2nd and 3rd gear are having an issue after computer checking done. That's why it received a faulty reading of the gears temp or function of them.
However, I wonder if the sensor was the issue or not, but after changing the speed sensor, the car now is much better than before.
Thanks.
Jan 23, 2022 at 10:33 PM
