Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Highlander
Brakes
Caliper
Replace/Remove
caliper bolt torque specs?
2012 TOYOTA HIGHLANDER
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
TJMOWBRAY
MEMBER
FOLLOW
Changing the brake pads on the vehicle listed above and needing brake caliper bolt torque specs.
Jun 27, 2025 at 8:44 PM
CERTIFIED EXPERT
The front caliper torque specs are
Torque : 34 Nm (347 kgf-cm, 25 ft-lbf)
The rear caliper torque specs are
as well. Let us know if you need anything else.
Jun 28, 2025 at 12:38 PM
