I have a P30 one ton step van with independent front suspension. The inside front brake pad fits into the steering knuckle with the anti-rattle clip on the bottom. Does the bottom edge of the anti-rattle clip hang down outside the channel so that the brake pad can spring back off the rotor when the brake peddle is disengaged or is the whole clip suppose to go up into the channel?
This is the type of caliper that is held in place using a wedge and one set screw.
Jan 19, 2017 at 7:32 PM
