Codes C1252, C1256, and C1310, Brake not Effective?
2006 TOYOTA HIGHLANDER HYBRID
245,345 MILES • V6 • 4WD • AUTOMATIC
BLESSING EWOBOR
  • 754 POSTS
Hello, the vehicle brake system is not very hard to depress. Even if depressed with enough effort it is not effective. When the vehicle was scanned, the codes that were found on the ABS were C1252, C1256, C1310.
What could be the problem?
Sep 2, 2023 at 1:12 PM
All of the codes are related. It could be something as simple as a stuck ABS motor relay or as major as the brake actuator assembly.
I attached diagnostics below. Take a look through them and let me know if you are comfortable performing them.
See pics below.
Sep 2, 2023 at 10:37 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you very much.
Sep 3, 2023 at 6:08 AM
I didn't realize this was you. LOL. You are very welcome, my friend. If you have a chance or if I can help, let me know.
Take care and let me know what you find. I'm interested in knowing.
Sep 3, 2023 at 8:46 PM
BLESSING EWOBOR
  • 754 POSTS
Good afternoon, sir.
I will notify you sir.
Sep 6, 2023 at 5:47 AM
BLESSING EWOBOR
  • 754 POSTS
Thank you very much,
The brake system is now working effectively. Replacing the component below solved the problem..
Sep 11, 2023 at 6:01 PM
Thanks for the update. I'm glad the problem is resolved.
Take care of yourself and as always, feel free to come back anytime.
Sep 11, 2023 at 8:43 PM
BLESSING EWOBOR
  • 754 POSTS
Good morning, sir.
Please, where is the accumulator pressure sensor located on the ABS actuator?
Sep 21, 2023 at 2:01 AM
I believe that is integral to the brake actuator assembly. I don't recall seeing a separate sensor at any point.
See pics below.
Sep 21, 2023 at 6:50 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you, sir.
When I read through some of what you sent earlier, I saw accumulator pressure sensor, since then I have been searching for it on the ABS line, but I couldn't see any sensor. Lol
Sep 21, 2023 at 11:21 PM
You are very welcome. If you have a chance, let me know how things turn out for you. I'm interested in knowing.
Sep 22, 2023 at 1:08 PM
BLESSING EWOBOR
  • 754 POSTS
Good evening, sir.
The vehicle is working perfectly after the replacement of the brake actuator.
Sep 26, 2023 at 12:20 PM
Thank you for the update. I'm glad to know it's fixed.
Take care and as always, feel free to come back.
Sep 26, 2023 at 12:59 PM
