brake master cylinder connector?
2005 CHEVROLET AVALANCHE
202,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
Looks like the master cylinder is toast, so I am replacing it and bleeding the new one. I noticed that the old one had no connector plugged in. Do some of these have a place for a connector but not a harness to it? I saw couple of lines that were cut underneath it but looks like an extension wire that were spliced, but no connector to the wires, could be going to it or to somewhere else as this truck had so much extra wires for speakers, amps, extra-large fuses by the battery, etc. if there should be a plug, is it sold separately and what color are the original wires going to the cylinder?
Dec 5, 2024 at 12:39 PM
Yep, there should be a brake fluid level warning sensor here are the color of the wires. Check out the images (below). Let us know if you need anything else.
Dec 5, 2024 at 3:29 PM
BHAMDOC1973
  • 2,008 POSTS
Thanks. What is the part behind the master cylinder called? i think there is a long silver cylinder that could also be leaking.
Dec 5, 2024 at 3:36 PM
Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
Dec 6, 2024 at 9:31 AM
