how many brake lines?
1997 GEO PRIZM
260,000 MILES • 1.2L • 4 CYL • FWD • AUTOMATIC
ASHTIN DAVIS
How many brake lines are on my car? If i replace one should I replace them all?
Jun 20, 2017 at 10:33 PM
CARADIODOC
  • 34,306 POSTS
That depends on why you are replacing one line. Typically there are four steel lines, one going to each wheel, but there are variations on the master cylinder design. A few have all four steel lines leaving the master cylinder. If a rear line rusts out and starts to leak, it makes sense the other rear line is just as rusty and should also be replaced. The front lines are better protected from salt and water so they cause less trouble. They most commonly rust near the end where they attach to the rubber flex hose right by the wheel. Often it's not practical to try to replace an entire line from the master cylinder to a front wheel. Instead, cut the line in an accessible, rust-free area where you can slide on a fitting, then make a double flare. From there, install a union and a short length of line to replace the rusted section. For best success making the double flare, do that in a section of line that is straight. If you try to straighten a section that had a bend in it, the flare will form off-center and may not seal. This video will show how to make your own lines.
https://youtu.be/sO43p4ZFUiM
Jun 20, 2017 at 11:25 PM
BIGDAWG44
i had a problem with the front brakes locking up then unlocking when the car sits for a while, changed the brake boster and master cylinder, works for a few days fine then back wheel froze was not getting any brake fluid to rear left wheel, took brake line off and used a compressor and blew air thru the line, then change the proportioner. still can't get any brake fluid to that one wheel.
help and suggestions
Dec 17, 2020 at 4:02 PM (Merged)
MMPRINCE4000
  • 8,548 POSTS
I would think you have a clogged brake line, either the rubber ones or a steel line.
You should be able to bleed all wheels, best way is to use a compressed air bladder that fits over MC resivour (sp?).
