Brake lights/taillights turning on randomly while truck is off
2008 FORD F-150
140,000 MILES • 5.4L • V8 • 4WD
BEND902003
Key out and headlights off the brake lights come on and drain the battery. I have replaced the multi-function switch. The left turn signal won’t flash, but the right does. The lights stay on even with the brake pedal switch and the flasher relay pulled. I welcome any ideas or suggestions.
Jun 13, 2019 at 6:37 PM
BEND902003
Fixed I think. The ground above the spare tire seems to be the culprit. Cleaned and all is back to normal.
Jun 16, 2019 at 5:29 PM
Sorry for the slow response we were very busy over the weekend. Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Jun 17, 2019 at 1:12 PM
