brake lights stay on
2010 MAZDA 3
160,000 MILES
RONH12
Hi I am having the weirdest problem with my brake lights. I replaced the brake sensor located under the pedal with a brand new one but had no luck. Even weirder is that when I pull the fuses out for the lights they stay on but when I remove the internal light fuse they start working normal. Any idea what might be the issue?
Apr 3, 2016 at 9:40 AM
HMAC300
  • 48,601 POSTS
have it scanned for codes it may be a body control module problem.
Apr 4, 2016 at 7:21 AM
RONH12
Ok so I used my tester (Alcatel 708) and it does not have any error codes for bcm. I also discovered that the a/c does not engage.
Apr 4, 2016 at 5:34 PM
HMAC300
  • 48,601 POSTS
your tester may not be able to test for a bcm problem, i'm not familiar with that scanner. for a/c check relay and fuse under hood.
Apr 5, 2016 at 6:23 AM
