Brake lights are semi functional?
2009 NISSAN XTERRA
154,000 MILES • 6 CYL • 2WD • AUTOMATIC
SEAN D. ELDER
  • 12 POSTS
I’ve recently changed the brake lights on my vehicle; the issue is that they work as hazards, but not actual brake lights. There’s continuity on all the breakers the socket itself, and my battery is running at a bit low. Low enough to take a few seconds to start, but fine otherwise. Is there any other diagnostic criteria that I’m missing?
Aug 10, 2023 at 4:31 PM
Do you have power at the fuse # 20 on the right side of the fuse panel?
This guide can help:
If so, please test through the brake light switch, here is the location in the images below, also please go over this guide as well:
https://www.2carpros.com/articles/brake-lights-not-working
Here are the brake light wiring diagrams so you can see how the system works. Check out the images (below). Please let us know what happens.
Aug 11, 2023 at 10:57 AM
SEAN D. ELDER
  • 12 POSTS
I haven’t tested the brake switch, and I believe that may be where the problem lies. Worst case scenario I will be replacing it as soon as possible.
Aug 11, 2023 at 1:01 PM
Sounds good please let us know.
Aug 12, 2023 at 9:01 AM
SEAN D. ELDER
  • 12 POSTS
So, after replacing the old switch, the brake lights still aren’t working. I tested continuity on the connection to the switch and found that the connectors top female ports do not have continuity. Does this mean I need to change out the wire harness?
Aug 14, 2023 at 4:53 PM
SEAN D. ELDER
  • 12 POSTS
Another note. I charged the battery, just to make sure that there wasn’t a low power issue.
Aug 14, 2023 at 4:58 PM
On the brake light switch do you have power at the red/blk wire?
Test with the key on.
Aug 15, 2023 at 8:40 AM
SEAN D. ELDER
  • 12 POSTS
Don’t have a probe like that, I have a CL120. But I’m getting tone indicators from all four points.
Aug 15, 2023 at 8:48 AM
SEAN D. ELDER
  • 12 POSTS
I’m changing out the relay for the brakes. Hopefully this is the solution.
Aug 15, 2023 at 11:01 AM
Is fuse #20 good?
Aug 16, 2023 at 10:54 AM
SEAN D. ELDER
  • 12 POSTS
Yes, I've tested all of the fuses for continuity, and they are all giving tone.
Aug 17, 2023 at 11:31 AM
SEAN D. ELDER
  • 12 POSTS
As of this post, here is what’s been done to remedy this situation. Testing tool used: Klein Tools CL120 Voltmeter.
1. changed bulbs, and also inspected sockets, and tested for continuity: there is tone.
2. Changed and re-inspected fuses: tone from sockets and also new fuses.
3. Replaced brake light switch under dash above the brake pedal; tested socket continuity: there is tone.
4. Changed all but one brake/rear light relay (the sun was setting.) unsure of how to test for continuity in this case.
5. Checked the engine fuses related to the brake or rear lights; no replacements made: there is tone.
Once again, the odd thing is that the top rear brake light bar is functioning, but not the two on the rear; And yet the hazards, reverse, and turn signal lights are all functional.
Aug 17, 2023 at 11:54 AM
With the key on and the brake pedal depressed do you have power at the yellow wire from the brake light switch?
Aug 18, 2023 at 9:46 AM
SEAN D. ELDER
  • 12 POSTS
Yes, I tested both fuse and cable with the key set to on. There is tone on both.
Aug 20, 2023 at 8:16 AM
Okay, now with the brake pedal depressed check the yellow and blue wires back at the brake lights bulbs, are the bulbs good?
Aug 21, 2023 at 9:19 AM
SEAN D. ELDER
  • 12 POSTS
With the key set to on, and the brake depressed, the socket is giving tone. The wires are black and green to the brake light socket.
Aug 23, 2023 at 8:05 AM
SEAN D. ELDER
  • 12 POSTS
Still the brake lights don’t work when brake is depressed.
Aug 23, 2023 at 8:10 AM
Okay, it sounds like the bulb ground is bad (black wire). I would use this guide to help check the bulb ground.
You will need to extend the lead on the tester or use a voltmeter.
Please go over these guides and get back to us.
Aug 24, 2023 at 10:51 AM
SEAN D. ELDER
  • 12 POSTS
Okay, so something interesting has happened. I was testing the ground for the taillights and noticed that one of the lights on the back of the vehicle switched to functioning as a brake light when the brake is depressed. So now the top bar and the passenger side bottom light is functioning as a brake light. The actual brake lights are still only functional as turn and hazard lights. Does this mean I need to change the connectors?
Aug 30, 2023 at 6:48 AM
