brake lights and tail lights don't work
1986 CHEVROLET TRUCK
V8 • 2WD • AUTOMATIC
ED G
I have checked the fuses, bulbs, etc. Still can't find why they aren't working.
Apr 29, 2015 at 8:38 PM
CARADIODOC
  • 34,306 POSTS
A broken ground wire is a good suspect, especially if there's a trailer wiring harness and someone made the connections with connectors that don't seal out moisture. Start by testing for voltage on the terminals in the sockets while the tail lights are turned on. If you find voltage on one terminal in each socket on each side, put the bulb in, then test for voltage on the brass base. If you find voltage there, the ground wire is open.
Apr 29, 2015 at 9:22 PM
