None of the brake lights including the high mount works. All other lights, signals etc work fine. Tested/checked all the fuses, changed the brake switch. Put all the bulbs including the brake lights on a tester and the the lights work in the sockets on the tester. Even went as far as changing out the multi-switch. what am I missing? I put the car itself on a tester and when you press the brake it recognizes the brake switch being activated.
Apr 15, 2017 at 5:02 PM
