Correct. If it works, then the switch is good.
This means either the turn signal switch is bad or the wiring to the bulbs is an issue.
Assembly Procedure
Important: Be sure that the electrical contact of the turn signal and multifunction switch assembly (2) rests on the turn signal cancel cam assembly.
Notice: Refer to Fastener Notice in Service Precautions.
1. Install the turn signal and multifunction switch assembly (2).
2. Install the 2 pan head tapping screws (1).
Tighten the screws to 7 Nm (62 inch lbs.).
3. Slide the 2 connectors (2) of the turn signal and multifunction switch assembly into the bulk head connector (1).
4. Pop the wire harness assembly (4) into the wire harness strap (5). Install the wire harness strap (2) into the steering column support assembly (1). Install the wire harness straps (3) onto the wire harness assembly (4).
5. Install the upper and lower shrouds. Refer to Steering Column Trim Covers - Assemble Off Vehicle (Column Shift).See: Steering Column > Removal and Replacement
Dec 6, 2020 at 12:34 PM
