If the center brake light works, then the only other item that can fail is the turn signal switch. Here is a wiring diagram for the system so you can see how it works. Also, I have included how to change the switch out. Check out the images (below). Let us know how it goes.
Mar 18, 2025 at 11:58 AM
SAMGREW
MEMBER
Changed multi-function switch, brake lights work fine. New problem. Drove car to get gas. When I started to accelerate, I heard a sound like fan blades hitting something. Car slowly picked up speed and will not shift unless you let off the gas. Changed filter and fluid with no change.
Apr 7, 2025 at 10:22 AM
CERTIFIED EXPERT
Good job getting the brake lights fixed. Sorry, we only handle one problem per thread, please post your new question here, you must be logged in.
