brake lights
1983 CHEVROLET CAPRICE
50,000 MILES
TAUREANDRAGON
  • 4 POSTS
Brake lights won't come on. Tail lights come on all turn signals work hazards work. I am assuming fuses are good cause all the other lights work.
Feb 5, 2016 at 11:35 AM
HMAC300
  • 48,601 POSTS
check brake light switch and t/s switch may not be sending power to brakes.
Feb 5, 2016 at 2:01 PM
TAUREANDRAGON
  • 4 POSTS
Changed out the brake switch that didn't do it. What does it take to change out the ts switch?
Feb 7, 2016 at 11:25 AM
HMAC300
  • 48,601 POSTS
you have to pull the steering wheel and need a special tool to get to t/s switch. but check it first. check white wire to see if power is going in and dk/grn and yellow to see if it's going out if it does it's not the t/s switch then check dk/rn and yellow wires at rear to see if power is going there. if it is then check blk wire for ground it could also be a bad socket
Feb 7, 2016 at 11:36 AM
TAUREANDRAGON
  • 4 POSTS
Thank you. Not good with electrical so this could be fun. Could you elaborate on the 'bad socket'
Feb 7, 2016 at 11:40 AM
HMAC300
  • 48,601 POSTS
where the bulb plugs into
Feb 7, 2016 at 12:12 PM
TAUREANDRAGON
  • 4 POSTS
All the tail lights and hazards still work even the third brake light comes on when hazards are on
Feb 7, 2016 at 12:18 PM
HMAC300
  • 48,601 POSTS
do what I said in last reply
Feb 7, 2016 at 12:39 PM
