brake light stays on pedal goes to floor front chamber of master cylinder keeps going dry,
1989 GMC C3500
165,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
TODD THE TORCH
MEMBER
FOLLOW
no pressure on pedal front of master cylinder keeps running dry cant see fluid coming from any wheel
Apr 27, 2014 at 3:23 PM
CARADIODOC
CERTIFIED EXPERT
Sometimes brake fluid leaking from a rear wheel cylinder takes a while to show up, but to be leaking fast enough to have the pedal go to the floor, it should be pretty easy to find it. If nothing else can be found, loosen the bolts on the master cylinder and pull it forward to see if fluid is leaking out the back and into the power booster.
Apr 27, 2014 at 3:39 PM
TODD THE TORCH
MEMBER
ill give that a shot tonite and get back to you thank you.
