Brake light on dash panel on
1993 TOYOTA CAMRY
100,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
KIP9666
While driving through San Francisco up and down several hills the indicator light came on seeing that fluid was low added fluid till full light remained on after discovering a bad hose replaced hose now brakes are applying themselves to the point of stopping the vehicle without pushing brake pedal so replaced calipers both sides problem still happening light still on brakes still grabbing by themselves can you help me? Thanks
Nov 28, 2014 at 11:57 AM
HMAC300
  • 48,601 POSTS
aa pro scan abs system for codes may be an abs problem.
Nov 28, 2014 at 12:04 PM
KIP9666
While trouble shooting discovered having all line blenders open and mashing the brake pedal several times then closeing all bleeder valves then bleed lines as designated by manual solved my problems with dash light and brake drag as of today no longer having brake problems thank you for your time and help
Dec 6, 2014 at 7:50 PM
