I need to replace one brake light bulb socket and wiring harness on a 1998 Ford Contour, base model (I think). The car is old enough that the part I need has been discontinued and cannot be found in any wrecking yard I have access to. Is there a compatible updated part that I can splice in to replace both sides? I'm also hoping you can tell me why the engine will randomly rev up for a few seconds when applying the brakes?
Thank you for your time, and information. It is truly appreciated. :)
May 14, 2025 at 1:15 AM
