Brake light does not illuminate
1995 JEEP GRAND CHEROKEE
250,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
RPOLLARD66
My driver side brake light does not illuminate when depressing the pedal. The passenger side and the third light both work. Fuse is good and I assume the brake light switch is good because the other lights work. Is it possible to jumper a wire from the other light to the driver aide and make it work? Tried testing but no luck.
Oct 4, 2018 at 4:19 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Did you try replacing the bulb first? You might want to check the ground wire on that circuit side. Look for looseness/corrosion/etc. I have attached a wiring diagram for your truck and a few tutorials for you to view. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Oct 6, 2018 at 6:37 PM
