the brake light comes on when I brake hard but not when I drive normally. Why?
Jun 13, 2017 at 4:28 PM
HARRY P
CERTIFIED EXPERT
Have you checked the fluid level in the master cylinder? If it is low and then you hit the brakes, it could be tripping the sensor that controls the light. If the fluid is low, I would suggest checking the brake pads. They are probably due to be changed.
