Thank you in advance. I have a problem with my van that feels like a brake problem though I've had almost a complete overhaul done on the brakes. History: Van was fine, went on a seven hour trip up and down mountainous areas during heavy rainfall at times. Coming home, brakes were grinding quite heavily. Took it to a shop where they supposedly turned the back drums. Brakes were not grinding anymore but then I noticed that they were now having a slight jittery feeling in the pedal and steering wheel. I took the van on a test drive using the brakes a lot (about twenty minute drive) the front wheel hubs were very hot and especially on the passenger side (and no heat on the back). Took it to another shop for a brake safety check, they gave a complete okay, saying it may be a slightly warped drum. Still feeling comprehensive, I took it to another shop where they replaced the front calipers. That shop said all the front brakes looked okay, but the old calipers (that they replaced) did have some wear on them. So, I took it on another test drive using the brakes somewhat moderately (thirty five minute drive), and the the front hubs felt somewhat warm again but had more even heat, meaning one side was not hotter than the other, but the jitter - when I apply the brakes continues. I have had it to three different mechanics and need to go on another long trip with the same mountainous roads. I am so afraid to proceed though something doesn't feel right. Van stops fine though. Backing up to my first statement here. The first shop told me that the front brakes needed a complete overhaul but two other shops didn't find that to be the case. I replaced the front calipers as what I thought was a last ditch effort. Also, after the first shop worked on the brakes they felt a bit stiff under my foot, but after the second shop replaced the calipers, the brakes felt a little softer, the way they should. The jitter worries me and the way the front brakes heat. I'm not sure that the brakes in the front should heat like that?
May 13, 2019 at 10:18 AM
