Now after 16 days I need new pads again! The last time only the inside pads were completely worn to metal. When I had the right front wheel bearing changed in September my ABS was messed up and only after the bearing and both front seat bars were replaced did it happen. The brakes would shudder when pressed after. A mechanic pulled the ABS fuse and it drives like normal. Except after all that I have had to replace my rear rotors calipers and pads 3 times and needs to be done already after 16 days. No mechanic understands and I need to get it fixed.
Feb 4, 2020 at 8:10 AM
