These are extremely common items at every auto parts store. That's probably why they don't bother to advertise them on their web sites. You can also buy a whole roll of line that has to be cut to length, then you slide on the soft metal nuts, then form the double flares on each end. The double-flaring tool is a specialty tool, and not horribly expensive, but it's way over-kill for the one time you'd use it. Also, my experience is since that bulk steel line has been bent into a coil, once you straighten it out, the double flares always end up off-center. I don't trust them to seal properly. Also, as a point of interest, once the flare is formed, the last step is to bend the tube down with the tool. Never crush it as tight as you can get it. Just bend it enough so it seats on the fitting it's getting attached to. When you tighten the nut, the flare will finish squeezing itself tight. and it will have some space to bend so it matches any irregularities in the seat.
The pre-manufactured lines already have perfect double-flares that are guaranteed to seal. These lines will be in a display box with common standard lengths to pick from. Typical lengths are 12", 18", 24", 36" 48" and 60". Obviously you don't want one that is an inch or two too short. If, for example, you need a line that is 51" long, you could use the 60" line and put some S-bends in it to take up the extra length. Form those bends so there's no high spot where air could pool and be hard to bleed out. You could also buy a 36" and an 18" line, and use a union to couple them together.
Almost all brake lines are a standard 3/16"-diameter, but around this time, some manufacturers started using different styles of flares. You must use a line that has the same style of flare. To add to the frustration, some manufacturers, Ford in particular, use a double-flare on one end and a metric "iso-flare" on the other end. The auto parts stores will have those special lines in stock too. If you need a union to couple two lines together, that will also be listed as a 3/16" fitting.
The best approach is to remove the old line and measure the length it needs to be. Take at least the two ends to the auto parts store so the salesman can match it up to the new line. Your new line is not going to have that wire wrapped around it. That was done by the supplier that sold that line to the car manufacturer. Without that wire, it's pretty likely the new line isn't going to be held snugly by the metal tabs on the axle housing. All you're interested in is the new line has to be held solidly so it won't slide back and forth, which could cause a hole to wear into it, and it has to be supported so it doesn't vibrate. Vibration from road bumps will cause the metal to "work harden", meaning it will become brittle, then crack at a stress point, typically near one of the line nuts. I use nylon tie straps because they fit every occasion, and they're fast and easy.
Since my daily drivers are old, rusty vehicles, I replace a brake line about once every two or three years. I just bought a set of six pre-manufactured lines at an old car show swap meet for $9.00, but at an auto parts store, expect to pay around five to ten dollars for one piece. They also have something new within the last few years. That is the same line with an anodized coating to resist rust. Those would be a good value for a relatively new vehicle that is perhaps being repaired after a crash. For old rusty vehicles, a standard line is going to outlast the car, so that added expense of the anodized coating isn't necessary.
As long as you have the two ends, and you know the length, any parts store employee will find the right line. Often that display I mentioned is tucked away out-of-sight. You can also find these lines at any farm and home store and at a lot of hardware stores.
Apr 14, 2021 at 1:50 PM
