Brake fluid leak in the transmission
1997 FORD RANGER
230,000 MILES • 3.2L • 4 CYL • 2WD • MANUAL
DEREKLOWE81
I have a 97 ford ranger that is leaking brake fluid in the transmission. And I have no pressure of the clutch. Any ideas on there the leak is coming from.
Aug 18, 2015 at 7:15 PM
If the fluid is seen only at the transmission and not the clutch master cylinder, the slave cylinder must be leaking.
Aug 18, 2015 at 8:10 PM
