Brake fluid flow to firewall distribution block
1992 LEXUS ES 300
162,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
DISTRIBUTION BLOCK
Brake fluid will flow only to LR service brake port of firewall distribution block , but not to RR or LF when brake pedal is depressed.
Jun 30, 2017 at 4:26 AM
HMAC300
  • 48,601 POSTS
try a power bleeder or if you can find a scanner that will open all valves on ABS unit then do that then. bleed sounds like ABS valves are not opening.
Jun 30, 2017 at 6:34 AM
