Fluid is not coming to 1 wheel only after changing rotor and pads. I had a little ordeal w/the caliper for awhile, where I thought the piston was not all the way down, and it probably was fine. But, to get it out and change the boot and put it back in, I had to pump the piston out using the pump the brake w/caliper attached method. Now I can't get any fluid to that one and the master cylinder is full.
Mechanic at Brakes For Less shop said the ABS pump is bad then, and you know that can be an expensive fix. I read or saw I think on your page or somewhere that some cars have a valve that may just have tripped to prevent fluid lose and just needs to be opened back.
BTW, I can't tell a lot from that pic. Which number on there is the valve? When I find it, is it easy to open?
Thanks
Mar 15, 2021 at 9:56 AM
